BRetty
- Jul 16, 2020
- Los Angeles
- Franklin
- c10
All,
My fuel gauge has been wonky since I got my 73 C10. (A 73 that actually has an 81 dash and engine/trans)
It reads correctly above 5/8 of a tank up to full. Below 5/8, it just sticks at 5/8. I've run out of gas a few times, mostly because I was in denial about my gas mileage being ~5mpg.
So I replaced the sending unit a few months ago. I checked the new unit before I installed it, it read 0-89 ohms as I moved the float, just like it should.
So I installed it, but I actually had about half a tank at the time, so it just went to 9/16 this time. We had cut out a random loop of extra wire in the sending line.
Same problem. Tonight I finally got the bed moved back and checked it at the tank. It's reading 47-48 ohms, despite I think I am below 1/4 tank.
Is it possible there is a blockage in the tank that is holding up the float?
I will run a ground right from the battery as a last check, but next I guess I open the tank and peer inside.
BR
BR
