GXPWeasel
- Nov 5, 2019
- Kansas
- Greg
- 1982 | 2015
- Sierra C15 | Silverado Z71
- 5.0 | 5.3
Okay, so I've read through multiple post on here regarding break in procedures for a new engine / cam, and threads regarding setting the timing, and making sure that you're getting oil pressure to the engine first, then start for the first time, so you don't dry fire it.
Here's where I'm confused though, or maybe stumped is a better word.
This isn't my first engine rebuild, but it is the first with a complete tear down, machine shop inspected, and assembled with non-factory parts with the correct tools. I rebuild a 350 from my '72 Skylark when I was in high school. Even converted that from a 2 bbl to a 4bbl. That engine was just a remove original parts, and put the originals back in, with new gaskets. Then I also built a 5.0 for my '92 Silverado, but it was basically stock replacement parts, as I was transplanting from a 4.3 to a 5.0. Didn't have great success with that one, but that's another topic. The point here is that I've done this before, but not when I've cared so much about the details, and had the correct tools.
Now that I do have the correct tools, and care about the longevity of my 305 that is being rebuilt for Daisy, I need to know how to proceed. See below.
I have read that once you get the engine started, you want to get the engine up to 2500-3000 rpm as soon as you can, and run it there for 20-30 minutes to ensure you break in the cam. Then you also want to drive the truck for 100 miles or so, varying the engine load / speed. Okay, I get that, and don't have a problem with that procedure. HOWEVER, how am I supposed to do that if I'm also starting from zero, pun intended, with my timing? If I'm starting fresh, with my cam dialed in at 0* per instructions, I will have no advance timing at all. What do I do first? do I dial in the timing, finding my preferred timing BTDC, then do the cam break in procedure? Oh, and to add to this, I've got a rebuild carb that I'm trying to dial in as well. I have no clue what the fuel trims / idle settings are going to be right off the bat. What if it takes a few starts to get the engine just to idle???
Help me out here guys... What say you on suggestions as to what should be my first concern? I'm not far away from doing this right now. I can choose to set the engine, then finish building the front clip around it before I fire this thig up (probably the route I'm going) or I can just set this thing in, and get it dialed in first, then finish assembly on the suspension / front clip.
I need advice.
I need advice.
