Extended brake hoses
BallOrust
Airdrie,AB
Ivan
Scottsdale
Im installing a 2” lift on an 87 chev v10, the brake hoses are in need of replacement is there an extended option available? I see them for 4-6” lifts but not for a 2” lift. Maybe there is a slightly longer than stock length for another application that can work? Any help is appreciated.
Iirc, a hose for a 2wd is a little bit longer. By how much, I don't remember.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
Get the shortest ones that ORD sells. They are made by Crown. You can get a kit with two fronts and the line that goes to the rear axle T junction.
BallOrust
Airdrie,AB
Ivan
Scottsdale
I’ll look into that thanks
ccacuna12485
