Engine problem
alc4819
Virginia
Avery
k20
I’ve got a 350 with a turbo 400 trans, it’s having trouble starting and ides high sometimes, also when a load is put on it backfires and won’t downshift. Anyone else had a problem like this? the engine has a smog pump which I think might be the problem or the carb
Need more details. Pics?
Sounds like potentially carb issue, timing issue, vacuum leak, low battery.... could be lots of things. When was the last time you set the timing and idle mixture screws. What carb do you have? Have you checked vacuum at idle? Have you looked for vacuum leaks?
alc4819
Virginia
Avery
k20
Here are a couple pictures, I haven’t had the truck long so I haven’t set the timing and idle mixture screws, I’m not even sure how to do that on this truck, it’s a quadjet carb and I haven’t noticed any vacuum leaks
born2Run83
West Texas
Justin
GMC - C1500
5.3L LM7
When you’re driving it, and is under a load or higher rpm and doesn’t downshift, what do you eventually have to do so it will? Or how does it come to a lower idle and stop to shut the engine down?
alc4819
Virginia
Avery
k20
Usually when it will not downshift I have to shift it into second. Sometimes I’ll get in to go somewhere and it’ll run perfect plenty of power and no problems at all. I also went to shut it off today and it kept hitting on a few cylinders, thinking it may be a carb issue
1973c10
Don
Welcome to the site
Shorty81
Baby Boomer
North West ohio
Darren
Welcome, nice looking Chevrolet
Rickf
Grafton NH
1974, 1954 & a 1937
Is the "downshift" switch hooked up to the gas pedal and tested for power?
Snoots
Roger
Jimmy Sierra
Check the vacuum line from the metal tube to the modulator on the tranny.
Babs
Ottawa Valley
Chevrolet CUCV
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Dieseling.... sounds like the timings off.
Corvette Ed
East Tennessee
Eli
Welcome aboard from East Tennessee
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
Craig
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
Retard the timing, sounds like too much advance. Rotor viewed from the top turns clockwise, so loosen the dizzy clamp and turn clockwise just a little if you do not have a timing light.
ballencd
Columbus, NC
Charlie
1988/1991/1983/1984
V10 Suburban/V1500 Suburban/M35 bobbed w/dump/M1010
5.7/5.7/LDT 465-1c/6.2 diesel
I'd start with a full tune up before I messed with the carb. You need to know where you are starting from.
TBSS GUY
