Emblems. Custom deluxe and Silverado fender and dash.
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Found these in/on various parts truck that Ive bought. I have no use for them because all my trucks are the wrong year/make/model of square. I'm not really in need of selling them, because I was planning on just keeping them for my emblem collection, but I thought they're might be someone somewhere that really needs one of these to complete the set.
So here they are...
A matched set 73-80 Custom Deluxe 10 fender emblems, and matching dash emblem. Came off a 76 K10.
One 73-80 Silverado 10 fender emblem and matching dash emblem. Came off a 78 C10.
One 81-87 Custom Deluxe 20 fender emblem and matching dash emblem. Came off an 84 K20.
One 81-87 Silverado 20 fender emblem. Came off am 85 C20.
All the 70s badges are in great shape, tabs are solid, no rust, not cracked.
Both the 80s emblems are missing they're tabs and would need glue to put them on, and the 80s Siverado badge is cracked and missing a peice on the bottom.
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
I also have a bunch of 90s chevy and gmc emblems, and a grill emblem for a square.
And I know where I can get a 78 Scottsdale 10 and 74 Custom 30 fender emblems, if anyone needs those, I can go pull them.
RoryH19
Rory
R10 Silverado SWB
I know this is for emblems but it seems you have a lot of parts. Do you have the radiator hold downs that go on top?
I need diesel ones specifically.
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
I have hold downs for a 78, that had a 350 and an automatic. That I'd be willing to sell if I cam find them. I also have a 454 heavy duty radiator non trans cooler, that I should have the hold downs for.
I have a 6.2 diesel blazer, but I can't part with those.
Would either of those work?
RoryH19
Rory
R10 Silverado SWB
Thanks but need the diesel ones.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
I don't think the hold downs are different on the diesel. I swapped a diesel in place of a 350 and the only difference was the mounting location on one side.
RoryH19
Rory
R10 Silverado SWB
The diesel ones are taller in the middle where the 350 goes down. I thought they were the same too until I tried to install the plastic filler panel over the rad that says caution fan. There is about a 1/2 gap where they screw on.
This pic is from a 85 diesel.
custodian
Catawba
William
5.3 LS, 350
So here they are...
How much for the Custom Deluxe 10 emblems?
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Oh okay. Well sorry.
If I ever deside the part out or give up on my diesel blazer, I'll let you know.
And the other are available if need be.
What if you just put a 350 gas radiator in it?
custodian
Catawba
William
5.3 LS, 350
[/QUOTE]
I used the diesel radiator brackets on my 85 when I switched to a 350, had to slightly modify them to fit over the CU730 radiator. The only thing I have left of the diesel stuff is the fan shroud, filler panel and the weight that was on the 700r4.
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Hmmmm
I've been accused of not charging enough for my stuff, so...
I looked online, used ones go for between 25 and 50 each, new ones go for between 50 and 100 each.
How about 50$ for the set of 2, 60$ for all 3 (including the dash one). You cover shipping, which would be about 8.50$
RoryH19
Rory
R10 Silverado SWB
Sounds good, thanks.
Need the diesel ones for my swap setup.
RoryH19
Rory
R10 Silverado SWB
I used the diesel radiator brackets on my 85 when I switched to a 350, had to slightly modify them to fit over the CU730 radiator. The only thing I have left of the diesel stuff is the fan shroud, filler panel and the weight that was on the 700r4.[/QUOTE]
I found the filler panel over the rad locally. Now just need the brackets.
78C10BigTen
pennsylvannia
C10 BIG TEN
So here they are...
Im interested in the silverado 10 ones....
Villano
