- Dec 7, 2010
- Southeast PA
- Paw Paw
- Chevrolet Tahoe LT
- 5.3, 4WD
Sit on the porch and wait for me, I'm almost there lol.
He can hold his breath too.
Acuatually !!! aka Actually... I might be able to learn you something about that rear spring dimmensions as far as length. For whatever reason, depending on which RPO code and if heavy duty or not, C10 can have either 52 or 56 inch rear springs. The only other model can have either 52 or 56in springs is K20. So 2wd half ton, and 4x4 3/4 ton can be either from the factory. The rest are pretty much as you'd expect. K10 is 52in rear and C20 is 56in. So being that K20 can be either, I'm moving my K10 springs hangers and installing the C20 rear springs. Just seems to me that the C20 rear springs are going to raise the rear. So how does the front get raised to match in OEM. Is it in the shackles, spring height or what? I'm fairly certain 3/4 ton front K springs can be 2 or 3 springs depending on the RPO codes.
i have also seen what appeared to be a factory 52" 11 leaf pack that came off of my 81 K30 cab and chassis truck.
as for the front springs to match the rears, you can either to an add a leaf, or a zero rate in the front, depending on how much difference, and how much you want to correct it.
i thought it was odd too, i was going to strip them down to 4 or 5 leaves, and install them in the rear of the K10 i was building at the time. opted to leave the stock 52s in it when i discovered they were also 52s.For real? 11 pc 52in length and not 56??? I've seen the 11, but it was 56in.
I think one of my K trucks is going to end up with the 454 that is in the 84 C20, so I'll likely want to add a 3rd spring anyway for the added weight.
I'm thinking the 84 C20 is going to be the truck that gets the Olds 455 with the Variable Pitch Torque Converter Th400 using the motor mounts out of the 80GMC that originally had the Olds Junky 350 diesel. This way the motor, trans and all will be in the OEM positions, OEM crossmembers, driveshafts and all. Only thing I have to do the trans, is when I rebuild the Variable Pitch Th400, instead of the 9in long output shaft, I'll put the short output shaft that is threaded in the end for the bolt on yoke. The truck is already set up for BBC and Th400, so this Olds Powertrain swap should be nothing more than swapping the motor pads off the frame that came out of the 80 Diesel truck, and moving the starter wires to the drive side instead of the passenger side.
Thanks Andy. Yes, it does look identical to the K20 springs earlier. Is this your K20 or K30? I'd almot like to compare K30 springs too. Then someone else has a K20 that is 2 springs and looks identical to my K10 and K1500. I'm still wondering what decides if you get 2 springs or 3 springs up front. I thought it might be big block gets 3, but the last K20 was small block.
Those are actually the original springs in my '77 Blazer. I still have the front springs from my '88 Burb (it used to be a K10) and I'm pretty sure they are only 2 leaves and the ends are shaped different. My K30 already had the lift springs when I bought it.
Screw the rear blocks, I would go shackle flip. It's too easy to do, and cheap. If you plan on pulling a heavy trailer, or heavy tongue weight trailer, I would do all spring lift rear. The blocks can break springs under heavy loads, and the shackle flip can bend the shackles under heavy lateral forces.
