Cure for SM465 Sloppy Shifter
Bagged Dually
Joplin,Mo.
Kris
CUMMINS 12 valve
Looks like a good idea I just don't know about using the radiator hose clamps on it...I think if I wanted to fix something this route I would have at least used a band clamp or something....
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
a hose clamp is technically a band clamp. and they're not there for anything but making sure the roll pins stay in place. mine doesn't have a clamp on it, just the roll pins.
I'm curious about fixing the wobbly weener at the end. It's labeled "snout" in the diagram. Just weld that up too?
rainyraven
wilhoit az
Ben
k10 cheyenne
this is good info, guess i better check this out before I put that trans in my truck ;)
adriner
Out in the sticks, PA
Adam
k25, c20
350 nv3500, 6.2TD th400
I found the best thing to weld that with is a 6011, many mig and 7014 beads broke til I found that out
GEB
Newton Iowa
Chad
K2500
If you're using a stick welder, 7018 Rod would be my preference.
GEB
Newton Iowa
Chad
K2500
Hey! I've been meaning to join a forum or two and finally got around to it! Thanks for watching my vids!! Ill have my custom tranny shifter built and posted soon!
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
How many folks have attempted this? I got mine out of the truck, soaked it in solvent overnight, and hit it with the torque this morning. The foul smelling smoke rolling out of the shifter smells like burnt rubber to me. There is not an internal rubber bushing i
s there?
TBSS GUY
