Cool Simple Upgrade Ideas
MadOgre
NA
NA
NA
NA
NA
Found a couple of simple and relatively inexpensive cool upgrades for our ol squares.
What ya all think ?
http://www.amazon.com/Headlamp-Conv...bs_263_10?ie=UTF8&refRID=18WRD4XJ4VJKN2SQABWT
http://www.amazon.com/Genssi-Projec...0F0V3K3&dpSrc=sims&preST=_AC_UL160_SR160,160_
http://www.amazon.com/Foxnovo-Porta...im_200_10?ie=UTF8&refRID=0HB7245J7SSEMM2YBCV3
http://www.amazon.com/Astra-Depot-C...im_469_11?ie=UTF8&refRID=0GN0WQQ9YVK6GHC7CK59
I like the H4 lamps cause the accent lighting could simply be hooked up to an ignition on source and that way you would have day time markers on all the time with out even having to think about it. Just turn the key and away you go! Kinda resembles the new look designed into the new trucks. Plus you get brighter lights on top of all that. Just not sure what to do about the second high beam only light in the quad setup or if a guy should just run double low/high beam units on both sides?
Or if you want just straight up LEDs you could go with these! :)
http://www.amazon.com/Genesis-Light...5R06SB0&dpSrc=sims&preST=_AC_UL160_SR160,160_
The USB conversion is pretty straight forward. I like the illuminated one but also the other one that retains the 12V/DC power plug just in case you need to plug an adapter or something in.
I was thinking it would be cool to weld in the factory hole and then drill 2 holes instead of just one and run 2 of these???
I was just thinking about that USB upgrade over the weekend. Would be a great upgrade for charging phones and such. No a fan of the halo fad but to each their own on that.
yevgenievich
Viktor
sad
very sad
less sad
I have placed usb plug in the center console on my suburban. Works well as my phone usually would sit in the front slot of the console
The88
Mhmm
South Louisiana
ThatGuy
I actually have a few of the bluesea dual usb bulk heads at the house. Will post pics when I get em hooked up. 1 for the front, 1 for the back seat and 1 for the rear.
Villano
