Considering manual to auto swap.
TCK1
Idaho
Travis
k25
Hello all,
I’m considering a swap from a Sm465 to an auto. I recently had my Sm465 rebuilt in my 81 k25, while the mechanic was in there I had him replace the clutch as well. 6 months later this pickup is going in for the 5th time because the clutch keeps having problems. It has been replaced once since the original work was done covered by his warranty. I never had a problem with the clutch before it was taken in the first time. Right now every so often the clutch pedal starts vibrating and the clutch starts whining when depressed. This was the reason why it went in for the warranty work. Now it’s doing it again. Getting progressively worse as I go. I’m about at my wits end with this continuing problem. Any ideas on what is going on would be greatly appreciated. This is why I’m considering a swap to an auto. With that being said which auto transmission would be the easiest to swap to. Considering I’ll probably have to switch the transfer case, and drive lines as well. But the least amount of modifications would be preferable.
Do you know specifically what brand and grade of parts were used? I've seen various clutch issues that were caused from cheap, low quality parts.
Also, assuming you have the original 465/208 combo, a TH400 with "tall style" 208 adapter will be a bolt-in swap. You can also use the '85+ style "short" adapter but you will have to use an '85+ style trans crossmember as well. Your stock drive shafts will be the correct length.
Turbo4whl
Downingtown, PA
Wayne
Jimmy
Andy has this right. The problem is getting and identifying the good parts. The first clutch I put in my '74 were parts house, rebuilt pressure plate, new disc and bearing. The 3 finger type pressure plate had one finger crack right away, new clutch would not release. Bought all new parts from the dealer for twice the price and had no problems. This was years ago, I doubt the current dealers have any parts for our trucks other than an oil filter.
gsparky
