Carburetor rebuild
bucata206
Silverdale WA
Anthony
I found an old unknown brand 4 bbl carb that my dad had sitting in the garage for years. I was thinking of rebuilding it and using it. Two things. One, are they difficult to rebuild? Two, Is it worth getting a rebuild kit and rebuilding it, or would i just be better off buying a new carb?
Aside from going to Napa and buying a rebuild kit, I really am not sure where to start with this project. :Insane:
Stroked
Beloit, Kansas
Jared
Take some pics and post em up or get the numbers off of it so we can figure out what it is first. It might be worth rebuilding and it might not.
bucata206
Silverdale WA
Anthony
I apologize for the delay on the pictures. The carb is in storage. So I know 0 about carb systems but looks like a 4bbl carb and found that it is a quadrajet carb. So thoughts? Worth rebuilding or but a new one?
SlickGTP
Houston, TX
It's a later model QJet... As far as whether or not it's worth rebuilding, I wouldn't say no, but personally I'd probably look for one that was made just before they put the electronics into it.
That said, I've heard that there's a way to remove the electronics, but don't know the exact process used to seal up the hole in the top plate when that's done.
robert8096
Goose Creek SC
Robert
The Qjet can be a bear to rebuild and tune. Do you have a stock or aftermarket intake on the truck? Stock is most likely a spreadbore carb mounting and aftermarket is most of the times squarebore mounting. The Qjet is a spreadbore and would need an adapter to to mount to an aftermarket intake. If you have a stock spreadbore intake and want to use a Holley or Elderbrock carb it will need an adapter.
If your looking for a good rebuilt Qjet, these people are the best. I have one and love it.
http://www.smicarburetor.com/
bucata206
Silverdale WA
Anthony
Ok do track one down the doesn't have all the electronics on it? Do they sell those new or do I have to find one someone is selling one used?
towin'gmc
Montrose, CO
Chad
C2500
Hey Anthony. The quadrajet is a great carb but complicated for your first attempt at rebuilding I think. I have saved a couple of them for future needs. Just contact SMI and let them send you one with no electronics rebuilt. No need to buy new. If you want a new unit I believe Holley has Q-jet replacement carbs. Your linkage should fit OK or at least ask about that before you buy so you need to tell them what manifold is on your truck.
bigcountryguy19
Sealy texas
josh
6.2 diesel
Personally, I would throw that carb in the nearest river lol, but that's just me, I like holleys
Driver4r
Nebraska
Trevor
k10,c20
The carb on my truck is a Holley Re'maned Q-jet, so i have the best of both worlds :rofl:
My Uncle put it on the truck befor i bought it from him.
But with that aside, Q-jet is by far the best all around carb and will pull the best MPG as far as carbs go. As far as rebuilding one, at first they might be intimidating, but if you dont rush into things and loose parts and read the instructions, Its pretty straight forward. But i agree with the others on here, avoid the electronic version, I have one that i converted to non-electric that i had on my monte.
bucata206
Silverdale WA
Anthony
Great thank you guys! I'll see if I can buy a rebuilt one. What is SMI that you told me to contact to get a rebuilt one?
robert8096
Goose Creek SC
Robert
Just call SMI and tell them what you got, they will ship you the correct carb. I told them year, engine size, modified or stock, transmission, and they shipped me the carb.
bucata206
Silverdale WA
Anthony
What is SMI? I wasn't able to find them online
Villano
