- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
This may seem like a retarded ass question, but beings the front axle (d44 in this case) in my dads 75 k25 is fine, his engine is fine, but his transmission is toast, and he needs a lot of u joints even if he fixes the transmission and his Np203 is probably a little worn out anyway.. I wanted to know if you could just find a 2wd tranmsission and appropriate driveshaft and make them work? The truck sits higher like mine, so likely has HD springs I would presume.
I was just asked to find a reasonable way to fix the truck since the transmission is ripperoni. I have a th350 mated to an np203, but a half ton, but with the front end components he needs and the primary uses of the truck as it stands, a 2wd even if not permanent wouldnt be a bad life for it, just so it stops sitting. but I dont know if there would be ramnifications of the front diff not having a driveshaft holding against the bearing(maybe the hubs could be converted to have lockers, then left unlocked?)
Its a longbed wheel base 4x4 3/4 ton which has its original drivetrain and axles, 44 up front, 14 in the rear, and 400 SBC with its np203/th350 pairing.
as far as putting a trans, th350 or 700r4 can be found rather easily around here for not bad, 2wd versions recently not so bad at all.
So even if this seems stupid or just enormously weird, any insight would be appreciated. I never even heard of the idea but unless a np205 th350 adapter isnt expensive and has the same driveshaft lengths as a np203(which I doubt) and as the original sm465 (which I would really doubt) off my 77 or my 80, I dont see a way to use my hardware without equally needing to size up new driveshafts or going so deep that he could have just had a shop fix/replace whats broken i got more than one th350 for a 2wd application, not sure if being from a car would mean a smaller shaft or anything but its worth noting.
We have a neighbor nearby that has been eyeing up some of my doors and I could see what he has, but hes mostly got later 80s square stuff
It should be noted my dad currently has a 96 silverado that.. uh.. has seen better days but if it had an untimely death, it has a 4l60e but half ton - that being said, an electronic transmission isnt out of the consideration if the electronic controller isnt hard to do. My cousin has a late 80s F body and he is looking to go from his 700r4 to a th350, for some reason, but eh...?
