Can I use a c60 diesel tach on a 6.2 diesel?
m1028cucv
california
john
k30 (m1028)
I’ve been trying to find information but I just can’t. I’ve also tried to get a yes or no answer but I just can’t my question is can I get a gauge cluster with a 4000 RPM diesel tach from an 81 through 87 medium duty Chevy dump truck with the caterpillar diesel or Detroit diesel and put it in a 6.2 and plug it in and have it read correctly? It seems like none of those engines use the alternator output
In the gas trucks, the tach has it's own harness. I can only assume a diesel tach would be the same. So you would wire the tach to wherever you would get the signal on a 6.2 diesel.
Turbo4whl
Downingtown, PA
Wayne
Jimmy
m1028cucv
california
john
k30 (m1028)
Turbo4whl
Downingtown, PA
Wayne
Jimmy
Then I would hook a tach/dwell meter up to that tach pin and see what reading you get. The factory GM tach's have 3 wires. Positive, ground and a wire to the coil. I have not dealt with a CUCV alternator, but that pin on the alt. must have a pulse signal.
Cryptik
