RanchWelder
- Jan 14, 2023
- Earth
- Blazer
- 355ci
My new Big Block Chevy engine has been diagnosed with a bad oil pump. (***Trans was working great when it was taken off the road... 4L80E vs 10.5 FF 14-B).
Hoping to change the oil pump/pickup and verify the rod and main bearings for damage/wear, while engine remains in the truck.
It's either a 1999 or 2001 K2500 Suburban... but the engine mains are similar or the same for both bottom ends... (YTBD...)
(If it's the 8.1L, all ready set to handle the crank sensor mod, while under there... if it can be wedged out in pieces and replaced...)
With respect to crank bearing measurements and inspection while on the truck, what do you guys have for advice for me, while oil is dripping in my face, removing one bearing cap at a time?
Will be using a new Fowler Micrometer Engine Bore Gauge set, a new six piece outside micrometer set: 0"-6" .0001", and a good used 6" Digital Caliper...
(Hoping to avoid plastigauge...)
The BatCat is inspecting the tools... he'll be holding the camera later on... BatCatCam...
1) (a) What kind of wear numbers can I expect from an engine with 180-200K miles on bearing wear? (Exact mileage to be determined...)
(b) What range is acceptable and when does it need to be swapped with a different size bearing?
2) What is the best procedure for measuring with the Fowler set?
3) Can this be performed pulling one cap at a time, or mains first, then rods and in what order?
4) Can I replace them all, if suggested, using this method, without screwing up end play? How do I verify end play with everything still in the truck, if it needs to be verified?
5) Can the job be performed without a piston falling out in my face? How should I prevent this from happening?
(If it happens, can it be put back in from underneath and/or how tough is it to do, without a spring compressor?)
5) Do I need to replace the rod bolts and main bolts, before this gets started? Can I reuse the stock bolts, so long as they are in the exact same location?
(If not, and I can avoid buying stretch bolts, what style/brand works well for stock rods and upgrades the bottom end for strength and retains balance?)
6) With the caps on rods/mains, what is recommended for torque during measuring? Can I reuse the old bolts for this step, or do I have to use the new ones, if required?
7) Is the high volume pump a worthwhile upgrade, considering the original pump failed? (*Will it require a deep screen intake... see question number 9).
8) How will I know, without removing the camshaft, if there may be cam bearing wear?
(Can it be determined via pressure readings after the bottom end is redone?)
9) Should I be looking into a deep pan with a baffle, so the pump does not run dry at 5%-8% grade, where I live and drive?
(If suggested... Does anybody have a good used Deep Big Block Chevy pan for sale? I can weld in the baffles, if it does not have any.)
10) Is there a way to gauge stretch/wear on the timing chain, check if it is worn out? (Planning to upgrade this at a future date.)
Hoping to get enough advice so this engine can be saved...
The number of o-rings and line disconnect tools and replacement clips/retainers to be replaced on any modern Big Block is daunting.
Kind of a nerd when it comes to making certain the o-rings are good everywhere...
The truck has been sitting for 3 years. Pictures posted when available...
If this thread has to be moved because it is a newer engine/vehicle, please let me know...
I'll be primarily taking/posting pictures of the Bottom End/Bearing Inspection/Replacement process.
Hopefully, others will learn what you guys suggest be performed... as the best ideas get hashed out by the professionals, who may generously offer their time to guide this repair.
Pictures of your used examples of crankshaft and bearings would be great, so we can compare the wear and measuring process vs what's under my pan...
To be continued...
To be continued...
