JamesSam
- Feb 15, 2023
- VA
- Sam
- Silverado V10
- 5.7 L 350 v8
Hello Square Brethren,
Unfortunately the motor for my drivers side door window has failed finally. Right in time for the great spring weather that is perfect for cruising without AC. It only goes down about 2 inches then makes a loud stuttering clamour and goes all the way back to the top and makes the same sound when all the way up. With many house and life expenses happening all at once I have decided to take the job on myself after doing some research to save some $$. I am not interested in upgrading to a faster version like the one LMC has Kevin Tetz doing the video for. I just want the window to work like it did before. I don't mind waiting 20 seconds for the window to go down and back up, I just want it to work and don't want to have to install new components and then find a place to ground and mount brackets etc.. Y'all know what I mean. I plan on greasing up all the moving parts really well before re-install.
So, please lend thoughts on a "best or better" replacement OEM style power window motor that you all might suggest?
