MadOgre
- May 4, 2014
- NA
- NA
- NA
- NA
- NA
You might be able to spring that last bit of distortion back into alignment.
Release the cross-member where it is bolted to the twisted rail.
If the web is twisted inward at the top:
Locate the point on the rail where the distortion is most pronounced.
Then, using a 36" pipe wrench (with the jaws tightly clamped to the rail on the upper flange - and the handle pointing up), try pulling outward with a bouncing motion.
Do this in a few other places on either side of the original spot.
Check the plane of the web for plumb.
You might find that the web is now perpendicular to the horizontal plane of the cross member.
Obviously, if the rail is twisted so that the web is canted outwards at the top, the procedure is the same. But, in that case, the torque is applied to the bottom flange. Also, you might need to use a shorter pipe wrench (and more Norwegian steam).
Cool thanks Jerry.
Im gonna try and bend that cross member straight and then see where Im at. How ever I just might have to replace it
It has a few more bends than I can get the camera to show
