Bed cover build with/power lock
Hoodbj
Billy
R10
Here's the day one start of a flush mount bed cover build. The frame is made of 16 gauge 1 inch square tubing. The hinge is a 1 inch piano hinge. The sheets for the cover are 16 gauge 4x8 sheets of steel. It still has a ways to go. I plan on putting 2 inch flatbar around the edge and gas struts to help lift (it weighs about 200 lbs). Will try to update pics next weekend when further along. Material cost less than $200.
Hoodbj
Billy
R10
Here's a pic of the frame
Hoodbj
Billy
R10
And a pic of the hinge
Hoodbj
Billy
R10
The under side
Hoodbj
Billy
R10
Rear view
Hoodbj
Billy
R10
I am planning on putting the 1/8 inch by 2 inch flatbar half overlapping the bed and the rest overlapping the bed cover. I will put a self adhesive rubber seal under the flatbar where it sits on the bed to make it weather proof. I forgot to mention the cover rests on 1 inch angle iron bolted to the inner lip of the bed rail. When finished I plan on painting. I am undecided on painting it red to match the truck or painting it black. Maybe even rhino lining it when I do the bed ( as you can see from the pics the bed needs it). Any suggestions?
350runner
tx
Ceasar
Dude this is looking cool
Sent from my LG-LS980 using Tapatalk
Bed cover build
That is phucking awesome
Hoodbj
Billy
R10
Thanks fellas, it's really not even that much work. The plate material is thick enough to weld with a wire welder but thin enough to cut with a metal blade and jigsaw. Hoping to finish it up next weekend exept paint. Going shopping for gas struts today. I couldn't find a flush mount for our trucks and the over the rails hard covers cost twelve hundred so I figured what the hell, I'd give it a shot.
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
I built one for my S10 I had and it worked great but like you said it is heavy. The lil extra weight gave my truck a lil better ride due to loading the springs a lil.
Hoodbj
Billy
R10
Heres the gas lift supports. The cover is now easy to open. All that's left is the flatbar edging. I bought the rubber seals today to put in with the flatbar.
Hoodbj
Billy
R10
And you are correct smurph, the extra weight seems to be a benefit. I hope it helps with gas mileage too!
Hoodbj
Billy
R10
So what do y'all think , painted black, painted red or rhino lined? Still undecided
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
Looks good. I would go with black to contrast the red.
John81287
Mchenry,IL
V20
Bed cover build
I think black rhino lined so it looks like a tonneau but it clearly isnt
Andy-14
