skysurfer
- Oct 23, 2010
- west coast
- John
- 1989 Suburban
- V2500
- 5.7/TH400/NP241C
I'm in the process of installing a Sanden compressor but since I know little to nothing about ac I need to ask a question or three. Go easy on my lack of knowledge, this is like standing in front of the class without pants. Anyway, my intention is to get the components installed and have my local mechanic pull vacuum and fill.
Working on a burb with rear ac. I need to flush the evaporator on the firewall and the rear unit (the forward components are new).
1: I have read that the initial flush should be reverse to normal flow so am I correct in thinking the evaporator gets flushed top to bottom?
Concerning the rear, I removed the expansion valve from the back and temporarily installed a piece of hose to complete the loop.
2A: With this done, can I blow ac flush through the lines from the engine compartment and expect a thorough flush of the rear unit?
2B: And am I correct thinking the initial flush should be the larger (upper) of the two lines going to the rear?
3: And finally, the compressor came with oil but I'll need to add some to the system. Is it ok to add any additional oil to the accumulator?
