Kilian
- Mar 25, 2018
- Wisconsin
- K
- C2500 on its way to a K2500
In the process of rebuilding a 10-bolt front axle for my 4WD project and have the problem of the new ball joints being too tight on one side. Ball joints are new AC Delco professional or whatever the higher grade is called.
I've followed the instructions in the service manual to first partially tighten the lower ball joint nut (30 ft-lb), then tighten the adjusting ring for the upper (50 ft-lb), then tighten upper nut (100 ft-lb), followed by final torque on lower nut (70 ft-lb).
Right now it's pulling at around 36 lbs or more to move the knuckle. Any tricks to this that I'm missing? The pull effort was in spec of around 25 lb after I tightened the adjusting ring, but got way tighter by the end of the procedure. I'm wondering if I need to use a clamp to make sure that the upper ball joint is pulled into the axle hole completely before tightening the adjusting ring? Thanks for any help provided!
