Air Conditioning Delete
Powerhouse Ranch
3G Connoisseur
PA
Luke
1980 & 1988
C25 & V15
454 & 350
SO on the new Jimmy, equipped with factory ac, the entire ac system has been butchered.
This includes practically all ac lines cut and the entire ac compressor is gone. What would be the best way to go about this; remove as little as possible and yet still have heater capabilities? Thanks
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
You can check out my suburban thread if you want, I did an ac delete on my 84. I'm not sure how in depth I went but it should have been a decent bit. I should be able to answer any questions after that
Edit-pages 19-22 has pictures and some detail, and some banter
PrairieDrifter
North Dakota
Mason
PrairieDrifter
North Dakota
Mason
Everything has worked great, my only problem is that sometimes the blower motor will run on the highest speed for like a minute to 30 minutes, it's never the same, then it will shutdown the blower motor completely. All three other speeds work perfect and I have no issues.
I believe that either my relay is bad orrrr I had to pick a spot to mount my resistor block as there are no provisions, it needs airflow across it or they will burn up. I believe that when that little coil heats up, it makes contact with the firewall and shuts down the blower motor and that circuit. I also have a fuse holder issue on that circuit in the factory bulk head, this is causing me a lot of issues. I need to relocate my power source for now till I do a wiring harness. This could be my main issue for the high speed as well.
Powerhouse Ranch
3G Connoisseur
PA
Luke
1980 & 1988
C25 & V15
454 & 350
sounds like alot honestly. Any way i could plug the hoses and such at the accumulator and keep the housing? in other words keep some old stuff but clean it up and never use it? hypothetically....
PrairieDrifter
North Dakota
Mason
Yep that's for sure possible, that's half of these old trucks with a/c on the road today anyways. I slightly glanced over the "remove as little as possible part" lol
You don't need to plug off any of the a/c components for your hvac to work properly. Just make sure the box is sealed good around the firewall and around the evaporator inlet and outlet are sealed well. These are the only two openings to the outside world. The heater core inlets as well.
Then my only recommendation would be to snip the light green wire off and and seal it up so it doesn't arc or whatnot. This wire comes out of the main a/c harness and this is what tells the compressor to do it's thing, is unneeded for the hvac to function with heat only.
Powerhouse Ranch
3G Connoisseur
PA
Luke
1980 & 1988
C25 & V15
454 & 350
You don't need to plug off any of the a/c components for your hvac to work properly. Just make sure the box is sealed good around the firewall and around the condenser inlet and outlet are sealed well. These are the only two openings to the outside world. The heater core inlets as well.
okay sweet, are there special plugs/caps i can buy for the accumulator? where the holes come from (i'll obviously eliminate all the hoses)
PrairieDrifter
North Dakota
Mason
I meant to say evaporator instead of condenser in my last post.
Honestly I would just remove the accumulator to clean everything up a bit. Then I wouldn't worry about plugging any of the lines or inlets to the accumulator or evaporater, the reason I say this is, looking at your truck these components have been open to the elements for a while, in that case they would have to be replaced anyways to reinstall a/c, not just because the hoses are messed up, but because the inside of these components have to be very clean. The evaporator is basically the same principle as a heater core, it just works for the a/c instead of the heat.
Use 3m strip caulk for the outer box to firewall seal, and also use it for plugging the holes around the heater core inlet and outlet, as well as the evaporator inlet and outlet.
PrairieDrifter
North Dakota
Mason
This is my 79, my grandpa owned and I grew up in this truck. Factory a/c but the pump was ditched and brackets were swapped with non a/c power steering brackets, as well as the lines to the pump, so not as butchered as yours. All of that since before I was a small kid, and the heat has never failed in that truck. The a/c part has been open to the elements for yearsss but the heat has never had an issue.
Dmack
Central OR
Dave
Mine was butchered when my son got it, and he then pulled everything off that was in the engine compartment, including the box. I pulled the cab side plenum box out of a non-ac parts truck and swapped it into my ac truck, complete with the controls.
Then on the engine side, I just swapped in the non-ac blower housing and made a block off plate with a removable panel for swapping the heater core if necessary. Pretty simple swap and heat works well..The only thing I had to go back and change was the new heater core location was a bit different from the a.c. Version, so I had to cut a hole in the firewall for air to circulate through the new core.
PrairieDrifter
North Dakota
Mason
I also lied to you about what pages the content was on.... lol more drunk than I thought i was
pages 19-22
PrairieDrifter
North Dakota
Mason
Honestly I don't know what I'm doing wrong anymore, I think I changed some settings. And that's what's changing the page orientation for me.
Now I don't even know how it works if we have different settings. If it would show up the same for you as it does me.
I apologize for the wild goose chase:rotflmao:
Powerhouse Ranch
3G Connoisseur
PA
Luke
1980 & 1988
C25 & V15
454 & 350
pages 19-22
just now looked at your engine sizes, i think you may know a thing or two about 350s XD
Pugs Speed Shop
