tj43
- Jun 20, 2022
- Little Rock
- TJ
- V1500
Hey everyone. I know lots has been discussed on this topic, but I was hoping to consolidate a few of my questions and get some experienced advice on my specific plan.
My 88 Suburban V10 has rear AC. It still runs on R12. I put a new Delco pancake compressor and OEM oriface in it last year, recharged with R12, and it worked for 6-8 months before the system discharged. Obviously, I have a small leak somewhere. I think it is time to convert to R134. Servicing and re-filling R12 is just getting too complicated. Less and less places have R12 or want to work on those systems. My plan is this: convert to R134 and then track down the leak (I am thinking it should be cheaper, easier, and more environmentally friendly with R134 than with R12).
Steps for the conversion: The compressor I bought and installed last year is R134 compatible, so I am good there. I see mixed info about o-rings, the dryer, and the oriface. What parts do I need to make sure everything is R134 ready? Finally, I am confused about the refrigerant/oil measurements when we inject the R134. How much of each do I need and what ratios (keep in mind, the Burb has rear AC so it takes a TON of R12). Also, when tracing the leak, I have seen some say that the UV dyes are not good for the older AC systems. Should we avoid the dye and use a refrigerant sniffer?
I want to do it right, and do it once. I dont want to go broke, but I dont mind spending a little extra to cover all my bases. Thanks for any help or advice you have to offer. I sincerely appreciate everybody's help.
