87 v-1500 wheels
Wallace6
Wyoming
Ray
Suburban
Will newer suburban wheels fit? I know the bolt pattern is the same. I'm just wondering if the center hole is the same. I'm guessing the backspace is different and may need spacers? Please let me know,tires for 15s are out of control and usually have a set of 17s half tread or so around so tires would be free. Thanks
mtbadbob
Montana
Bob
V20
What year of Burb are you thinking of? I put the '99-2010 GM Alloys on my V20 & they fit fine, just a little snug around the rear hubs but no spacers were needed of any sort.
Wallace6
Wyoming
Ray
Suburban
I hope you are right? For some reason I have it in my head that the locking hub won't clear the center hole and will probably hit leafs on full turn?
Thank you
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
IIRC late model 6 lug stuff won’t fit square body 6 lug hubs. All of the GMT-400 and newer bodies have really small center bore.
The 8 lug stuff is hit or miss, and can sometimes be modified to fit. I’ve got a buddy with a late ‘70’s f-250 with GMT-800 factory wheels on it. They look pretty good on there too.
I suppose it may be possible to get late model 6 lug wheels machined to fit square body hubs but I haven’t personally seen it done. Also, you are right about offset most late models run a very positive offset compared to classic trucks, wheel spacers would also be needed.
Right, the 6 lug wheels on the '88+ trucks have more backspacing, along with a much smaller center opening that doesn't work with the older trucks.
The newer 8-lug wheels (through ~2010) fit older 8-lug trucks though without modifications. Except for Fords and Dodges that have a slightly larger center register than GM trucks.
