AyWoSch Motors
The Parts Guy
- Nov 6, 2020
- New Mexico
- Ayden
- K1500 Sierra
- 350ci V8
I'll try that
I checked that those wires weren't damaged, they look to be in good shape.So in re-reading your first post this started happening after doing the ignition system work, and I reading that correctly? I'm wondering if you got a new module that isn't giving the computer a strong enough RPM signal? If you have a spare I'd swap it out just to see, especially if it was lower cost or off brand module.
Make sure that none of the wiring is damaged where the injector wiring leads to the injectors especially where it passes from the outside to inside the throttle body sometimes it gets rubbed in that little rubber bushing it passes though or someone damages it putting the air cleaner one, some times it take a while for a wire crimped for that to actually become a problem so if one or more of the wires has been flattened even if it didn't break though the insulation it could be a problem. Feel free to post pictures of the wiring and engine it might not tell us anything but maybe we'll spot something.
Hmmm, didnt know that. I will have to inspect it.Ok here's another thought for you. There should be some ground wires attached to a stud on the thermostat. These ground wires the computer uses. The injectors are constantly fed power, and the computer completes the circuit creating the pulse though those ground wires at the thermostat.
Yes, IIRC one of the two bolts that holds the housing down is a double stud with a nut, should be some ground wires on that but I think the number varied from year to year.Hmmm, didnt know that. I will have to inspect it.
On the thermostat?
I agree, although it always seemed a tad bit ball-less when it did run with the TBI.@AyWoSch Motors Ayden, let me make sure I fully understand. So basically I re-read the thread and truck will run if you provide fuel another way.
So it you be really great if you could get a fuel pressure reading when the truck won't start. That would help you to figure out if it is a supply issue, or the ECM not enabling the injectors. Because those are the only two possibilities. Look I get it a running carbureted truck is better than a FI lawn ornament, but the throttle body injection does have advantages.
IF you think it's not getting proper fuel delivery you could try bypassing the electrical wiring for fuel pump.
When the truck won't start I assume you cannot see fuel being sprayed out of the injectors? IF the truck has a fuel pressure test port hook a gauge up to it. If you don't have gauge push on the shrader valve and see if you get a good stream of fuel out or just a dribble. You might just have a bad pump.... IDK. I get your thinking on switching to a carb so the darn thing will run, but if you can get this thing to run reliably TBI that would really be best I think.
