Wallace6
- Aug 4, 2023
- Wyoming
- Ray
- Suburban
Ok so I have an 86 burb. Original diesel but swapped to a 350,but suspension Wise I got a set of rear add a leaf,so 1.5 maybe 2". That would probably level it.
I also have a second set of add a leaf for the front which would make it have the rake it has now.
I'm thinking if I do front and rear add a leaf then a 1.t rear block kit that should work and be fairly level, clear 33s if I want and look pretty decent.
Anyone know where I can find a cheap lift block kit with new u bolts. I have a 10 bolt rear btw.
Thanks so much
Thanks so much
