- Aug 3, 2010
- Usually not in Ohio
- Andy
- '77, '78, '79, '84, '88
- K5 thru K30
I assure you I am NOT a "wimp". You keep saying there is more problems, and your basically (or atleast I am interpreting it) saying that the bad Tire was caused by another steering or suspention part. A busted cord is NOT caused from ANYTHING other then a Defect in the tire itself or foreign material in the roadway.
I have valued your opinions and your knowledge on this forum greatly. You have proven yourself to be VERY Knoledgeable in alot of different categories.
BUT IMHO If you have driven for weeks on tires worse then that at freeway speeds then I question your intellegence. I can understand hard finacial times More so then ALOT of other people on this Fourm. But I also realize that a broken cord is more then just "annoying" it is EXTREMELY dangerouse, not only to you but all the other motorist on the road. It is simply ignorance to jeapradise ANYONES life. That is 1 of the biggest reasons why Our state and alot of others require an Inspection prior liceeansing a vehichle.
I have had blow outs on alot of different vehichles from cars to 18 wheelers and NONE of them are any fun especially when your weighing 80,000 pulling a tanker.
No no, I don't think that the bad tire was a result of worn parts. I just think that the "uncontrollable shake", AKA Death Wobble, was a result of the bad tire AND worn front end part(s). A tire alone will never cause death wobble, there is ALWAYS going to be something else at least a little bit loose that is partially responsible.
Take my buddies old K5 for example. He had stock 31x10.5's on it and it drove absolutely fine. Then we mounted a set of old Wrangler RT's on it (like the military tire, but when they were still available in other sizes) that were knobby and wide, 31x13.5 I think. They were also out-of round bias plys. You could not (literally, could NOT) drive it at 30 mph because it had death wobble. It was not because of the tires, it was because of the tires AND a slightly loose tie rod. Replaced the tie rod and the truck drove fine again.
And yes, I was stupid for driving on those tires. Even though I was dirt poor and could not afford 15 bucks for a replacement tire, for whatever reason, I just didn't think that much of it at the time.
These days, I just see it on customers vehicles and THEY have been the ones driving them at freeway speeds. You wouldn't believe some of the tires I've seen come into that shop, I have actually taken pictures because it was so crazy, but I have since lost them. Our shop is known city-wide for specializing in suspension repair and we get a lot of business. A coworker has been there for almost 40 years and every now and then, we see something that even he has not seen before.
That is why I say to check the front end over really well. And even if nothing shows up, taking it to a good front end shop will turn something up. There is something else that will need tended to soon, I'd just about bet my truck on it.
