'81 bolt in high hump and clutch pedal assy.
Lugnut
Northwest Georgia
Jason
'79) 350/ granny 4-speed, '86) 350/A833 3-speed with overdrive
I am looking for a bolt in high hump for an '81 c10 for a 5-speed conversion, and a clutch pedal assy. for a hyd. clutch set-up.
Thanks
Thanks
I have one. Came out of my 82 Blazer. I'll get a pic if you are interested.
Lugnut
Northwest Georgia
Jason
Yes I am very interested.
Thanks
SquareRoot
I literally just sold an assembly to a fellow member 4 days ago. What 5 speed transmission you putting in? Factory hydraulic clutch only came in 85-87. I'm curious if the earlier trucks have the dimples in the firewall for the support rods? Did the earlier trucks with mechanical linkage even have support rods?
Lugnut
Northwest Georgia
Jason
I have a good NV3500 that came out of a '92 OBS that I am planning on using, so thats why I want a hyd. pedal assy. I know that are not know to be a strong transmission but it will be going behind a worn out 305 daily driver so I'm not to worried about it. That coupled with most of my wilder driving days are behind me. I have an '86 with a hyd. clutch set-up with an A833 transmission so I can do some looking and measuring to make it all work. The only thing that I don't have totally figured out is the speedo. I know thay make electric to manual boxes for that but still deciding on that or a GPS with a set of modern gauges to get rid of my warning lights.
loki1978
