700r4 year interchangeably question
JD02
United States
Cam
K1500
Are all 82-92 700r4s the same?
My 700r4 went out on my 85 gmc, wondering what years would work with my truck? Can’t really find any direct answers online
Are they all the same? No. Will they interchange as a whole? Yes.
For things that you need to know in a trans swap:
The inputs went to 30 spline in '86, so converter has to match
2wd and 4wd outputs are different lengths
Some models starting in '86 were electronic speedo output instead of cable.
yevgenievich
Viktor
sad
very sad
less sad
There is also the corvette case that will not have a transmission mount provision
JD02
United States
Cam
K1500
Thank you all for the replies!
GTX63
Tennessee
Ty
Strength/durability speaking, 700R4s up until 1986, not so great. 1987 -1992 are the goodins.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Look on the psssenger side of the case. If it has the St Louis arch casting line above the servo, and has a TV cable, it’s a good core to build.
Pugs Speed Shop
