700r4 problems
marks86
Latham, NY
Mark
12v Cummins
So I drive an 86 with a 700r4 in it; weird, anyways the truck started to not go into gear, I figured it was the fluid and filter, replaced them both and stilll wont go into gear, it does creep alittle bit in drive but will not clunk into gear, anyone have this problem before?
oneluckypops
Sedalia, Mo.
Luke
K30 SRW
when you changed the fluid what did the old fluid look and smell like? Did it smell burnt?
marks86
Latham, NY
Mark
12v Cummins
to be honest it looked like mud, nothing bad in the bottom of the pan though
oneluckypops
Sedalia, Mo.
Luke
K30 SRW
no black crud in the bottom of the pan?
I would tear the old filter apart and see what you find on the inside
marks86
Latham, NY
Mark
12v Cummins
no black crud, and the filter had nothing in it, it was just nasty
Sometimes you won't have anything in the bottom of the pan. If the fluid looks like mud, I'd guess that dark fluid is clutch material and you've probably burned up a clutch pack. Doesn't smell burnt huh??? Fluid looking like mud is NOT a good thing at all.
JOD26
