6.0 w/ TH400
Fr3zzo
pa
elliott
I have had this project a while I'm swapping a 6.0 into my 84 k10 and keeping the 4x4 with the th400 and t-case I don't want to make my life hard and would like a plug and play Harness but am having trouble figuring out what i need the 6.0 is an lq4 or lq9 i forget which but the harness should be the same? I think anyway any help would be greatly appreciated thanks in advance.
GH0ST
Daniel
6.0 LS
What would you say your budget is? If you’re looking for plug and play with the stock computer I’d recommend psi harnesses. If you’re looking to save some money then you can always pin out the harness yourself as I did. I’m not as educated as others in this forum, but I have some experience with swaps. Let me know if you have any other questions or need info on anything
78ALB
