1990 Suburban Square Body Fuel Pump Replacement
Bright Idea
Scappoos, OR
V 2500 Suburbans
I have a 1990 suburban (square body ) that I need to remove and replace the in tank fuel pump. I am considering an access panel in the floor of the bed. it looks as though this is possible but a bit tight due to the support member spacing. The pump is centered between supports but the two line connections are under a support by a little bit. Has anyone made the change out using this method rather than dropping the tank? I am not concerned about reinstalling the cut out. this is an old work rig and would always be covered by the bed mat. I have seen many you tube videos of making access thru the truck bed but not specifically a square body suburban.
SquareRoot
Cut it.
When you lift up the carpet or mat and clean off the floor, it's easy to see all the spot welds that attach the crossmembers to the floor. Those will be your front-rear opening boundaries. Iirc, the width of the opening needs to be rather large. Far to the right so you can get wrenches on the fuel lines, and far enough left to access a ground wire.
You will want to put metal back over the hole when you are done, especially if you ever have heavy objects tossed in the back.
Bright Idea
Scappoos, OR
V 2500 Suburbans
Thank You
I did exactly as you said. This will allow replacement of the pump without any structural integrity issues. Much easier than dropping the tank. I will be reinstalling the cut out using light flat bar straps in the channels with rivets and seal the seams with caulk.
The access hatch seems kinda hack, but it can be done nicely and not cause any structural issues or insulation issues at all. I've done it to two different Burbs.
It's a much different scenario compared to some vehicles, like a 3rd gen F-body for example. I absolutely do not support making a fuel pump hatch in those.
jcldtmom
