1987 Dump Truck Frame compatibility
GM_Mike
Canada
Hello, I was wondering if any of you know if an 87' dump truck share the same frame as a K series, or Dually? I'm looking to remove a dump truck bed and replace it with a dually bed. I can't find anywhere if they share the same type of frame, or if it's worth the hassle to put a dually bed on it. Any help is appreciated. thanks.
Big Chip
Michigan
Kevin
C35
It’s probably a cab and chassis truck which has a narrower rear end than a regular dually.
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
Make sure the wheel base is 131.5" for a standard cab truck. If it has the narrower chassis cab rear axle, it will end up looking like this.
JOD26
