1984 Turn Signal Switch
adammit
Hamilton
Adam
350 Ci
I cannot for the life of me find a replacement part for the turn signal switch for a 1984 K10 Pickup.
Rockauto shows the D626D as a GM genuine replacement, and I see it on amazon as well, but Amazon says it wont fit.. Can anyone steer me towards the correct part?
Thank you
adammit
Hamilton
Adam
350 Ci
Bought mine at LMC.
I was hoping on avoiding LMC as we get shafted getting those parts across the border here to Canada.. lol.
Will have to be a last resort for myself. Cheers
fast 99
Spokane, Washington
Amazons parts data base is horrible. Look up a brake self-adjuster kit it won't even say which side.
Bought a lot of parts from Rock auto. Just need to read the descriptions. They do a good job.
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
Rockauto is most always correct. You have to read the special notes. Amazon is not. I just got the that exact one, haven't installed it yet. But it has the right pin count and wire colors for my 84 suburban.
Turbo4whl
Downingtown, PA
Wayne
Jimmy
I have talked about this before. Buy this Caddie/ Olds switch, it will fit your square. Then you can have cornering lights.
ebay listing, click here
Cornering lights stay on while the turn switch is on, they do not flash. Of course you need to add the lights and wires. Easy to wire up, feed the orange wire from the light switch (middle wire of the 3 extra wires on the end of the plug). Other 2 are left and right.
IF you add bright high amp lights, you will also need 2 relays.
JOD26
