1977 C10 Silverado 350/T350 - reverse issue
Steppin Razor
Houston
S
C10 silverado
Hi all. Having trouble with reverse first thing in the morning. I shift into reverse but it doesn't engage. Eventually slips in when I give it gas, then it's fine the rest of the day. Fluid and filter are fine. Previous owner had it rebuilt in 2016. I thought maybe some vaccuum issue, but I don't know much about transmissions.
77 c10 350/350
MarineOne
Western New York
Lip seal on the direct drum is nicked and allows the fluid to bleed down overnight. Could cause clutch issues depending on how bad it is.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Pour an extra quart of fluid in. If that solves the issue, drop the pan and verify the full mark is even with the pan rail.
TBSS GUY
