1976 Chevy k10 vin numbers
legopnuematic
Licensed Junk Dealer
MO
Spencer
Should be a data plate on the driver's side b pillar. Lists the vin, GVWR, tire pressured
Sent from my Moto Z (2) using Tapatalk
Bennyt
Surprise
Ben
Most of the frames I've seen have are stamped twice and I've seen the stamps in 3 places. On frame in front of front control arms/ axle centerline, under the cab and under the bed behind rear cab mount. Usually all on the passenger side.
hoagster
California
K10, 1500
5.3l
There are several places the vin is located on the frame, and it probably changes by year. mine had one on top near the steering box picture #1, and on top of the frame under the cab pic 2, there is also a date and serial number of the frame on both sides behind the gas tank mounting area pic 3, but like I said that could change year to year or location of the plant that built the truck. good luck
caleb chapdelaine
Oroville California
Caleb
Thank you
caleb chapdelaine
Oroville California
Caleb
I found this today, is this supposed to match up with my vin?
DanMcG
Central NY
k10 k10
Probably the frame rail part #
Keith Seymore
Motor City
Keith Seymore
4.3L
The partial VIN is up on top of the horizontal web of the rail, not the vertical side.
k
starlinstephens
