I need a donut
scape
Springfield, MO
Shannon
LS
I have a 1985 350/400 out of a 2500 GMC. Running the stock exhaust manifolds with the A.I.R deleted. Also using the stock down pipes as the ole 2500 came factory with true duals. Like a dummy, I pitched the old donut exhaust gaskets on tear down and now I have no idea what size I need to put it back together. Purchased a pair from O'Really's and of course they aren't thick enough. Anyone have any suggestions?
Strick
Dunn, NC
Harold
C20 Crew
Seems like the Fel-Pro # is 8194. Worth a shot as it fits many SBC apps.
HS
Carb'ed Vortec 350
Never knew there were different thicknesses. I just get the size specified for the application.
I rarely mess with manifolds anymore, but in the past, my local parts store back then never wanted me to have them look it up by application. They just had me go in the back and pick the donuts I wanted.
These days, the stores don't stock sh!t for donut gaskets. I recently needed donut gaskets for the 350 in my van, they had to order them in. They were the correct ones at least, lol.
Carb'ed Vortec 350
I guess I'm lucky having a mom and pop store still in operation
I'd a tried the local Napa (still a great mom/pop type store) but it was late on a weekend so they weren't open.
Carb'ed Vortec 350
Strick
Dunn, NC
Harold
C20 Crew
I went to work in parts over 30 years ago. I knew how to find the industrial and "hard to find" stuff because I was patient enough to look in the books. The electronic systems in the parts houses still omitted quite a few parts that were "ordinary" or commonly used. I recently was looking for a u-joint and went to the store to look through the catalogs...which were no longer present in the stores. They don't even know what a book is! Fortunately I have the popular u-joint sizing and cross referencing book that I retained for myself from a couple decades back. I was easily able to find the conversion joint by simply looking in the reference. Things certainly have changed a lot over the recent years; if you cannot source a number electronically you probably are not going to be able to source it at all without doing some independent research. Happy hunting on your replacement parts.
HS
Rusty Nail
Rusty
350sbc
Reading?
Books?
I suppose you can look at an analog clock and know what time it is too!
Kids today..
(1982!)
HS
Unfortunately, I only know of one parts store that still has books on hand. It's several hundred miles from home. I've got a Napa Body Hardware book from 2013 that I have to take with me to the local store when I need to restock.
Strick
Dunn, NC
Harold
C20 Crew
I've got a student replacing the engine in a 97 C1500. The heater hose connector broke (of course) & I extracted the remains & chased thr threads. I spit the PN out for the replacement & he got out his phone & checked me. "Strick, how did you know that by just looking" he says. Here came the teachable moment. I told he & his classmates that although I hadn't slung parts for years now, I still retained many numbers by memory. Now, put down the damn smart phone & use your brain!
HS
Carb'ed Vortec 350
The store I go to has books, and they do use them for old stuff or oddball parts
3dbello
