After market head lights
Eli28
usa
Eli
What headlights do you guys recommend I was looking at these from LMC.
kkgp81
Kelley
exampleThe Phillips units. Not cheap but VERY nice and bright.
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
I like them very much. Very good pattern, and pretty dang bright. Ive had no moisture issues. And they take a regular bulb. Made of aluminum I believe and glass. I don't have the halos though.
Eli28
usa
Eli
Do they plug right in or do you have to wire them in?
PrairieDrifter
North Dakota
Mason
They come with conversion pigtails. Not the best quality but they haven't given me any issues. So yes they plug right in. May have to bend or cut the tabs on the back of the bucket to change bulbs if needed.
Eli28
usa
Eli
Got them plugged in today but they only turn on with the highbeams
PrairieDrifter
North Dakota
Mason
I vaguely remember having to repin a couple of wires on the conversion plugs.
Craig 85
Nashville, TN
454/TH-400/NP205
I used Hella conversion lights on my '79. They have an H4 bulb and glass lenses that look OEM.
HELLA 002395991 7" H4 Type Single High/Low Beam Headlamp​
sparky77
