I replaced the cigarette lighter and wired it to only work when the key is on. A small project but worth it.
Lol, that's one of my biggest gripes with a lot of older foreign cars. I hate when the lighter socket doesn't have constant power.
incubus2432
Grafton, Ohio
Shekkie
Interesting- why key on only ?
The reason the lighter didn't work was the wire to it was tapped shoddily and the socket was kinda beat up so when I went to fix it I added a relay along with a new socket. I can't think of a single reason why I'd want it to work with the key "off" and I know that at some point I'll leave something plugged in that kills the battery as the truck is an occasional driver with some farm duties.
incubus2432
Grafton, Ohio
Shekkie
What do you need constant power for? Just curious since I just charge my phone or run the occasional inflator.
Ajax19
Socal
Ajax
Use mine for a dash cam(so when your parked it will run with no key) but I have a dual battery selector so when I want everything off I use it I also wired my radio to run with the key off same for all the lights and siren that way I can use them and keep the keys in my pocket
In general, just so I can have my phone plugged in while I'm parked somewhere. But in other situations it's handy too, like plugging in my big spot light while setting up camp, or to power a small inverter while I'm on my laptop computer for work stuff.
PeteJr
NW MS
GMC Sierra Classic 1500
Wix filter had Made in china in spanish right on it :(
Unfortunately.........
I remember when most were made right there back home in Gastonia, NC.
And "unfortunately" I remember when they were $3.99 each.
I bought 3 at O'Reilly last week.......... $41.00 !!
Travlr
Central Utah
C
K20 Camper Special
O'Reilly's has gone off their nut, I think. I went in for some fuel line and they wanted over seven bucks a foot. I mean, I know stuff has gone up but HOLY! I walked out and went to NAPA to buy it for two bucks and change.
Carb'ed Vortec 350
Not just oreillys. The good fuel injection hose is sold by the inch. Locally, the last time I bought some it was $0.66/in. I could buy the cheap stuff for a couple bucks, but the good stuff will hold up better to the modern crappy fuel.
Camar068
10 yrs Air Force
Ordered Monroe load adjusting shocks for the front. Only $82 on amazon. The rears are the same type, so thought I'd make em all match. Helps I had a $75 gift card so only $12 out of pocket after tax.
installed these while I had the front body off during the engine swap. These ride like a dream! No bouncing or jarring.
ZMBKLR
Illandanoid
Charlie
I finally found a decent deal on the 56" 1825lb rear leaf springs for my suspension rebuild! They were cheaper than Rock Auto too. I have all the pieces for the rebuild. I'll be sending my gearbox out to be rebuilt to a quick ratio.
Where did you find this deal? I need a set of 56' springs for my 1979 GMC heavy half
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
Been wanting Dakota digitals for over a decade. Super simple and clean, it's the newer model vhx in white. Super easy to install, but very time consuming and tedious, constant up and down and chasing wires. I dont want to have issues or do it twice, so I took my time and did an above average job, not perfect, but there's nothing I felt iffy about.
I couldn't find any examples of a mount for the control box, that I liked. So I spent a good bit of time thinking and visualizing lol. I ended up going to the dash bolt and there was a hole next to it already, so I used a nutsert. Made up a bracket real quick, it's hidden in the dash so nothing pretty. You can't use the factory corner dash speaker with this mount, but I wasn't using it already anyways, wouldn't want a speaker magnet that close to the box anyways.
The protective film is still on it so it'll be more crisp and clear. Everything seems to be working proper. The ONLY thing I don't like is the speedo going to 160, it should be max 120, id like it to have more definition/hash marks and each 10 mphs displayed numerically. Gotta put the dash back together tomorrow.
Fastduramax
Uranus
K10 Silverado
Nice work Mason, I am dreading this job so much I've had my Dakota's sitting on a shelf for well over a year ! I can do wiring, I own an old Mack lol but I dread it !
PrairieDrifter
North Dakota
Mason
Thanks! I'm one of those tough to get started people too, but once I get going you basically can't take my focus off of it, I was out till 4 something am one night without even noticing!
Wire ferrules are your friend for this job!!! The crimper tool also, very cheap!
I had a couple aftermarket gauges so I had some of the extra wires ran already. But otherwise it was easy, definitely a few day project to do a nice job. There's a few things you shouldn't show on the internet and wiring is one of 'em lol. I ain't scared though.
Villano
