Ajax19
Socal
Ajax
Are you effin serious? I will have to check each and every filter from here on out. Grrrr.
Yeah really sucks, side note got my mirrors on can see clear into the bed now haha
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Same color door I bought from a burb . Pinstripes and all . Best thing I've bought because aftermarket just doesn't cut it in doors .
We had an 84 burb with dame paint scheme when I was in high school. Lol
The 84 is home with new starter, led lights working properly and new smooth a$$ throttle cable. It got rid of that loop that made it hard to press the gas pedal. If anyone has that same issue I can get one like this from him if any of y'all want one. He custom made it to fit right.
What info does he require for a custom unit?
82sbshortbed
Fuckemall!!
SE Texas
Doug
I'll ask him tomorrow. It made a huge difference for mine. It was really stiff before and now it's perfect. I'm guessing he'd need the measurements from firewall to cable bracket. All the new ones I've bought for it were 24" and was way too long.
Old60Driver
1983 K20 Silverado
Houston
Michael
K20 Silverado
More parts tool might be junk Ill let y'all know lol been raining so no work done yet
Let me know how it works out for you. Have a similar kit that I've been need to use. ;)
Drauka99
Northwest Florida, USA
C-10
6.0 LQ4
body work and more body work. I've been stripping a donor hood to bare metal and cleaning up some small dings and pinholes. At some point I think someone did a driveway paint job on it and used a concrete block to scuff it and then went back with 1 can per square foot of hood with spray paint. The sun baked that to a crackle finish here in FL and underneath is the scratched up original paint down to bare metal.
savagebows
Tyler, Texas
Tim
K1500
Only had mine 3 weeks so been doing alot. Drums, rotors, hardware, calipers, wheel cylinders, water pump, intake, carburetor, then found exhaust gases in the radiator, so pulled motor apart, removed, transmission and transfer case. Working on getting a decent motor put together now.
aaron06
