12 Valve swap
brandontwilson
redmond oregon
brandon
chevy k20
6.7 cummins
So i'm converting from a gas to a 12 Valve just curious on what all i need to change and get if someone wouldn't mind letting me know it would be much appreciated
1lejohn
texas
john
k-1500, 2500 HD
There is a bunch of info on U-Tube of these builds. The first step is welding the front frame for added strength. Do to the weight of the engine and the torque it will produce. I think someone on here has a build thread going . You can do a search to try and find the thread.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
This is a loaded question. Depends on what you want and have a budget for. Biggest question is what transmission your Goin to use. They make adapter plates for almost anything. I've got a 12 in mine with a zf5 behind it.
brandontwilson
redmond oregon
brandon
chevy k20
6.7 cummins
i was just gonna get a adapter plate so i can use my th400 or if i can find the actual transmission i was gonna use that
vr1967
Mississippi
Virgil
k1500
6.2L turbo
Depends on if its going in a 2wd or 4wd. And it’s intended usage. Running stock? Or intending to increase power?
I’ve done a few Cummins conversions, but everyone seems to have their own idea of what is the best way to do it
squaredeal91
Greg bush
1991 SB
You mean a Chrysler transmission? Im not a big fan of there newer automatics. I would stick with a gm transmission if your going auto.
brandontwilson
redmond oregon
brandon
chevy k20
6.7 cummins
its going in a 4wd pickup and for the time being itll be stock up until i can beef everything up for it so long run there will be a increase in power if that makes sense
squaredeal91
Greg bush
1991 SB
If I'm pretty sure the GM adapter works with all there truck transmissions witch is cool in case you go with an overdrive transmissions down the road. I'm curious as to what starter they say you will need.
brandontwilson
redmond oregon
brandon
chevy k20
6.7 cummins
yeah that one im obviously not gonna get everything overnight it'll take a bit of time but i'll watch some youtube videos and see what they use and what'll work with my budget lol
3dbello
