ChuckN
Bellinham, WA
Chad
I pulled the trigger and had a local shop custom bend pipes and install my Flowmaster 40s today. Even with the header flanges a little low, I’ll have enough clearance with our smooth roads around here. And it’s WAY better than it was by light years, even with bigger tubing. I’ll say it again, that Summit crossmember is sweet. The biggest challenge for them was getting around the e-brake cable on passenger side.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
That looks good! I broke down 2 years ago and had the duals replaced on my scout. So glad I did it!
Randy and Easton
North Richland Hills, Texas
Randy
C-10 LWB
E washed his and got door panels finally on… they only been sitting in the spare bedroom for, I don’t know maybe 4-5 months!!
Soundmound
North Central Washington
Dave
Scottsdale
I wouldn't be able to wait 5 hours to put new door panels on my truck. It changes the look with that new dash.
Ajax19
Socal
Ajax
Started this yesterday used 80 then 400 grit sandpaper follow up with a torch and some armor all for a free door panel restoration this could work on other plastic restoration Attempt at own risk
ChuckN
Bellinham, WA
Chad
Got the doors to shut with the single "click" method after doing the PEX trick on the door strikers. Man, that's the easiest thing I've done on my truck. Also gonna finally fix that high beam with condensation in it that's been bugging me...
Camar068
10 yrs Air Force
Took the grill out to paint. I forgot that I had put plasti-dip on it. I've got about 95% of it off. I'll not use that stuff on anything that isn't disposable or flat.
Sent a buddy after a drop bumper for the Thurrty...
Love those bumpers. I had one when I lived in Cali, it didn't make the move to Texas. :(
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Swept out the bed and was wondering what kinda bed spray or something I could put on it. Even with a paint roller that's not too expensive. I'm gonna have to strip off that black stuff that's coming off first.
Should I clean it up then primer it and then put the liner on? Think that would be better than just bare metal.
aaron06
