Justin Smith
- Nov 30, 2020
- Texas
- Justin
- K1500
- 4.3l V6
So my truck seems to be a bit of a unicorn. Its an '86 GMC stepside with a v6 engine and a wood bed. I recently decided to undertake the (much larger than anticipated) task of getting rid if the rotting sheet of plywood as well as the rotting original bed wood and replacing it with something sturdier and nicer to look at. I use my truck for truck things. Its main purpose is to drive me to our family land and traverse the pasture. My thoughts were to get replacement wood slats, and coat the wood and the bed strips in bed liner, all the way around before putting it all back in. I got all the way to the last bed strip and the last carriage bolt is directly above the gas tank. Do I really have to drop the tank for a single carriage bolt?!?!? I'm unable to find any info at all on my particular truck on YouTube or forums or anywhere. I'll post some pics to help me illustrate my issue. I may end up just cutting the bolt at this point but I wanted to see if anyone had an easy solution. Thanks for your help in advance.
