Wiring Harness? Choosing one?
Jordan Goodwin
Lobelville, TN 37097
Jordan
Looking at complete wiring harnesses for my ‘85 k30. American Autowire lists only one complete option on their website for an ‘85 chevy truck- their “classic update” kit, MSRP $1,069. Classic Industries has this same harness listed under “Universal Harnesses” for $883. Haven’t priced it anywhere else just yet. LMC does not have that specific kit, but does have an AAW harness “designed specifically for your vehicle”, that appears to have just a couple slight differences, don’t know what the difference is in plug and play abilities. That harness is $1,016.
I’m planning to keep this truck mostly stock. Which harness is going to be the easiest and quickest to install? Is there another option that’s easier?
Tonimus
Phoenix
Tony
C10 Suburban
Keep in mind that I'm a cheap son of a gun, too. The wiring harness in my race car is basically the cheapest AAW kit you can get. But I did their kit in my '84 C30 when I had it and that was one of the easiest kits I've done. And I've done too many.
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
Unless your stock stuff has been burnt up or badly damaged, I recommend just tidying it up and staying stock. The GM harness and fuse box is every bit as quality as anything available on the aftermarket
Dleslie212
Phoenix
Dustin
5.7L 350
I went with the Painless kit myself when i did mine. The difference being the documentation and instructions in the book
Doppleganger
OH-MI: Just like it sounds
I almost bought the OE replacement Painless kit - $700ish. What I wound up getting was a Painless kit for a GM column (the hardest part IMO) for <$400 as I am replacing the entire harness myself with relays, etc. Even had many more circuits for adding power windows, locks, etc.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Agreed! Even if you’re starting from scratch, you could buy a couple good used harnesses and build one far cheaper.
kittkatt381
