Will tires fit 15x8 rims
Cyrillious
Toronto
Cyril
K10 Suburban
I have 15x8 rims with 4.25 backspace to install on an 80' gmc suburban. The tires I got are 31x10.5 r15. These tires should fit the rims right? And would 1/4" spacers help clear the front tie rods?
Strick
Dunn, NC
Harold
C20 Crew
Strick
Dunn, NC
Harold
C20 Crew
Good to know.
The tires should fit the factory steel or aluminum rally wheels. My son-in-law has a Jimmy with 32x11.50's on the aluminum and there are no rub or fitment issues.
Strickland
Nope tires will not fit 15x8 rims. You have to run those without tires.Sorry,the title made me do it.
FireTruck1984
Michigan
1984 and 1984
If the rims you’re referring to are factory 15X8, they should fit and not need a spacer. But I’ve found that some Rallys (probably aftermarket) contact the tie rods. Check your fit with an empty rim before mounting your tires.
Cyrillious
Toronto
Cyril
K10 Suburban
This is what it looks like
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
This will fit no problem
2manysquares2care
