Wheel lip rubbing on UCA’s
Taylorb27
North Dakota
I posted this to the wheel and tire section but it’s probably better suited for this section.
looking at ways around this, I know I could run a spacer but the front fitment is just how I want it. Will be lowering soon. First question, would cut coils drop the UCA inside the wheel? Will be cutting at least a coil, more than likely 2 and doing an axle flip in the back. This is just a town cruiser so I’m not concerned much with ride quality, I’ll leave that to my other projects.
I’m sure a drop spindle would do it too but cutting is cheaper lol
Any feed back is sure appreciated
GXPWeasel
Kansas
Greg
1982 | 2015
Sierra C15 | Silverado Z71
5.0 | 5.3
In theory, cutting part of the coil will shorten the gap distance between the upper and lower control arms, thus pushing the wheel out a little on the bottom. However I think then once you do an alignment, it will just be right back where you started, so nothing gained. How bad is it rubbing? You could always grind away a little metal on the UCA (I would do that before I ground on the wheel lip). Any pictures?
Taylorb27
North Dakota
ya I’m going to take the wheel off and grind a bit off the UCAs. Not going to touch the lip of the wheel. I’ll put in a 5/16 spacer before I do that. I’ll try to get a picture
Taylorb27
North Dakota
So it’s actually rubbing on the ball joint plate. All I did was spent a few minutes with a green rolock disk and I’ve got an 1/8” of clearance now
jbahena95
