What tha... rear end is this,
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
Well there ya go! See if you can trade them your garden variety GM 10 bolt and run the positraction D60 in the Sprint :)
Thought of that, but he had already cut one axle. Plus, can't legally run limited slip rear ends....
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
So I just found some info. It appears it came out of a Jeep J4000 believe it or not, and common with the Power Lock carrier too. 5 lug Semi float axle rear end. Probably with 4.10 gears.
Has a tag with 3.54 stamped on it, assume it's the ratio. Yes sir I'm betting it will be a horse trotter instead of walker. It is belt drivin with a speed reduction pulley "system" so will be able to slow it down with resized pulleys..
Appreciate all the information, as well as opinions.
rodfarm
