what size tire can I run .
mtpcage
north Florida
michael
I have a 86 long wheel base 2wd , looking to see what size tire I can run without a lift. any advise with wheel offset also. thanks
It depends on how worn your front springs are and if they are the heavy duty spring option. But a 32x11.5-15 on a 15x8 wheel with around 4" backspacing should fit fine. I had that combo on a '79 2wd Blazer.
A 33x12.5 can fit on a 2 wheeler with heavier (taller) springs, but that would be real iffy on a 1/2 ton I would think.
larocque
quebec
Olivier
C15 sierra grande
6.0L vortec
Do you have a picture of your blazer with 32"
I only have pictures of pictures I took on a cheap disposable camera, circa '01.
dttoolman
