What is this part called in the Vacuum lines?
garzas23
Brazoria County TX
AJ
What is this component (circled in the pic) to the vacuum lines called and what does it do? It has a male vacuum port coming out of it with no hose. I am curious what its called and what it is supposed to connect to. thanks
Looks like an A.I.R. control valve.
He's right - it's the decel (deceleration) valve. It is part of the A.I.R. system:
Deceleration Valve
The deceleration valve is used with the AIR system to help prevent backfiring during high vacuum conditions, Fig. 17. Vacuum draws the mixture valve diaphragm down and opens the valve allowing air from the air cleaner to flow into the intake manifold.
A.I.R. System - description of operation:
This system consist of a belt driven air pump (s), internal drilled passages in the cylinder head or manifolds, piping and hoses, electric air control valve and check valves. The vane type air pump (s) supplies air through a centrifugal filter fan to the electric air control (EAC) valve, Fig. 11.
The electric air control valve directs air to either the exhaust manifold ports or the air cleaner, which also acts as a silencer.
On all engines except 1987 Federal V6-173 engines, at cold engine coolant temperatures or at wide open throttle conditions, the Electronic Control Module (ECM) will energize the electric air control valve solenoid, directing the air to the exhaust manifold ports. At higher engine coolant temperatures, the electric air control valve solenoid is de-energized, directing air to the air cleaner. Also at higher engine speeds, air is directed to the air cleaner through the pressure relief valve even though the solenoid may be energized.
During engine deceleration, a rise in the manifold vacuum signal to the electric air control valve, will cause the valve to direct the air to the air cleaner.
When the engine is operating in the closed loop mode, air flow should be to the air cleaner, with no air flow to the exhaust ports.
On Federal 1987 V6-173 engines, the Electronic Control Module (ECM) will energize the electric air control valve whenever the engine is started, directing air flow to the exhaust ports. Air flow will only be directed to the air cleaner during deceleration.
On all engines, the check valve(s), which is located on the air injection pipe, will prevent reverse exhaust gas flow into the air pump in the event of a air pump drive belt failure or exhaust system afterfire. When the engine is operating under a rich condition or if the service soon lamp is illuminated, the electric air control valve solenoid will be de-energized.
NOPHO84K30
north phoenix
justin
1984 silverado k30
K30 dana 60 corp14 ff
454 sm465 np205
I have a.i. r. On my truck but dont have that part anymore. Probly why everytime I shift it pops and back fires ......I have the smog pump air headers with one line from pump going to carb port ..might not be rightbut passes emissions....
87ChevyR10
Kansas
NA
NA
NA
A lot of motorcycles have a similar system installed. It basically injects fresh air into the exhaust system to help burn unburned fuel. If the system is functioning normally on a bike with aftermarket pipes, it will pop on decel. Trucks with the AIR system should respond the same. Only way to stop the decel pop is to delete the AIR system altogether.
burnt
