What is involved to switch from auto to manual
web365ster
california
cross
Chevrolet K5 Blazer
SBC 350 GM Performance Crate Engine
AUTO TO MANUAL
I'm deciding the direction I was to take my 86 and just wondered how difficult/possible and what all would be involved to switch . Going kind of the shop truck, slightly above rat rod kind of thing. I already need new glass and interior panels. Honestly I need a new wiring harness for the whole truck
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
It's worth doing. Did you want mechanical or hydraulic clutch?
All depends on what what setup you have now and what you're going to. Are you running a small block or LS or something else? Wanting an old school 4-speed or a more modern 5/6 speed? There are a few generic things you'll have to do regardless:
-remove shifter from column/swap out for a floor shift column
-remove linkage from lower column to trans
-cut a hole in the floor for the shifter
-figure out what flywheel/clutch you'll need
-pedals and either linkage or hydraulic systems
-driveshaft
-possibly exhaust work depending on your current setup and if it'll clear or not
AUTO TO MANUAL
@SquareRoot ,we got one. How do we move it to the what truck hall of shame.
Snoots
Roger
Jimmy Sierra
350 w/203
Get a $2.98 'FOR SALE' sign. Sell it and go buy what you want. In the long run, it's cheaper and easier.
OurDually
