AlexK10
- Nov 26, 2018
- Puerto Rico
- Alex
- K10 Long Bed
Hi, I have a beat up K10 (1984) that I've been fixing up. It has a 305 sbc, 700R4 trans and transfer case with wheel lock front hubs.
Anyways the other day I was messing around a steep dirt track testing the 4x4 which works great. However on one section a front tire lost traction and obviously spun and got me stuck.
Guess its designed that way from factory were one side looses traction and you dig a hole and get stuck?
My intended use for the 4x4 is around slippery boat ramps and any other scenario where I would need it while on dirt/off the pavement. I am not into hardcore off-roading or mudding or climbing etc therefore 99.9% of the time it will be on 2x4 with the factory rear setup back there on pavement.
Anyways: Is the front internal diff ring/pinion carrier assembly the same as the rear were I could find a used diff, weld it and swap the original so I do not destroy the original differential by welding it?
What specs should I look for when buying a used front differential for a 1984 K10?
If sourcing a used front diff or rear diff that would fit the front is impossible, what other options do I have before looking into a 250-300$ lunchbox locker for the front?
