CookieSoup
- Apr 1, 2018
- Seattle area
- Mike
- Suburban
Pictures and the Clist Ad MESSAGE ME THERE i will probably forget to log on here
https://seattle.craigslist.org/see/cto/d/bothell-1987-gmc-2500-suburban-k2500/6971689829.html
I think im the 3rd owner odometer says 77k and I might believe it the underside of the truck is very clean. I have had it about 2 years when I bought the truck it had a TH400 and NP208 in it and was more of a manual guy so rebuilt and put in an overdrive manual trans. Was building it into an overland truck but life is taking a turn going to see about selling the truck and building an overland trailer to pull behind my jeep. Don't really have to sell the truck but if I can get out of the project at not to bad of a loss ill switch gears.
Parts NOT GOING WITH THE TRUCK
-Winch
-ARB awning
-ARB fridge and slider
-roof top tent
-shovel and axe mounts
1987 GMC 2500 6.2 Diesel
40 Gallon tank
Barn doors
Manual Transmission
Manual windows
Power locks (didnt work never tried to to fix it)
Front end
10 bolt front axle4.10 gears 4 inch lift Via 52 inch springs
-new wheel bearings - Acdelco
-new rotors - Acdelco
-new pads - Duralast ceramic golds
-new calipers -
-new brake lines - Rudged Ridge
-new balljoints - ACdelco
-new u joints - Acdelco
-new tie rods - Acdelco
-new drag links - Acdelco
-52 inch front spring swap - DIY4X.com
-swaybar disconect - Offroad Design
-Warn permium manual hubs
Rear end
-Semifloat 14 bolt with factory LSD 4.10 gears
Motor
-6.2 detroit diesel
-2 new bigger batteries
-Cat Spin on fuel filter and water seperator
-new G60 Glowplugs
-manual ford glow plug relay
-upgraded (larger wire) glowplug harness
-new radiator
-140 AMP alternator
-new water pump Acdelco (2000 6.5 diesel)
-New fan clutch
-new duramx 21 blade fan
-AC system is not charged since i did the serpentine conversion
-new belt
Transmission
-new Clutch
-New Flywheel
-factory hydro clutch
-rebuilt NV4500 (1994 lowest range low gear)
-NP205 (round pattern)
-JB fabrications twin stick
-front and rear drive shafts rebuilt at Drivelines Northwest
Wheels/Tires
-5 Hummer H2 wheels
-5 35x12.5x17 Treadwright tires (old mud terrain pattern)
Other
-old ramsey front bumper
-front 2 inch reciver
-new Acdelco door locks and ignition cylinder
-larger front speaker and center speaker wired in to the CB
-JottoDesk center console
-Rhino Rack roof platform
-Snorkel
Extra parts
-Full Float 14 bolt rear end 4.10 gears
-4 inch front 47 inch front lift springs
-4 16 inch wheels and tires
-odd ball spare parts
-autometer Diesel tachometer
-Factory Service manual for the truck
-Factory Service Technical manual for the 6.2
-all the parts to do the AC recharge I think
-Probably more parts
-Winch
-ARB awning
-roof top tent
40 Gallon tank
Barn doors
Manual Transmission
Manual windows
-new calipers -
Rear end
Motor
-6.2 detroit diesel
-new G60 Glowplugs
-new radiator
-140 AMP alternator
-New fan clutch
-new belt
Transmission
-new Clutch
-New Flywheel
Wheels/Tires
-5 Hummer H2 wheels
Other
-Snorkel
Extra parts
