Frankenchevy
Proverbs 16:18
- Jan 3, 2018
- USA
- Jeremy
- Square
- CUCV
- Small
hey,
just messing around with software setting up my timing. I initially set it to what the interwebs said was stock vortec timing. I'm wanting to confirm if these settings are accurate. also, I've heard on here that tbi 350s came out of the factory with really low timing values and they can take more advance. I was wondering if my research was pointing to similarly conservative timing values that I could also advance.
my values are 15 idle, 36 cruise, 32 WOT. my curve is not really a curve, more like a curb--its all in at 1600 rpm. I'm going to play with smoothing that out a bit.
what is the consensus from the greater wisdom here? what is a good starting point for idle, cruise, WOT and all in?
Thanks!
Thanks!
